JanaRawlins
Feb 4, 2026 3:20 PM UTC
Feature request: Reusable, pre-approved style context for Figma Make (save + apply style sets)
Problem
Today, applying edit guidance in Figma Make relies on a manual copy-paste workflow (for example, repeatedly pasting guidelines.md and/or CSS adjustments into each new Make file). There is no native way to save a pre-approved “style set” and re-apply it across prototypes, which adds friction and increases inconsistency risk.
Current behavior
  • Designers must manually copy/paste the same edit guidelines (and any related CSS tweaks) into every new Figma Make file.
  • Updates to guidance require repeating the same manual steps across multiple files.
  • There is no centralized, reusable, permissioned style context that can be applied with one action.
Expected behavior
Provide a first-class way to create, manage, and apply reusable “Style Sets” (approved guidelines + optional CSS) to Figma Make files.
Proposed solution
Add “Style Sets” to Figma Make:
  • Create Style Set
    • Compose and save a named bundle containing:
      • Guidelines (markdown-style instructions)
      • Optional CSS overrides
      • Optional metadata (owner, version, last updated, tags)
  • Apply Style Set
    • Select one or more saved Style Sets and apply them to a Make file with a single action.
    • Support choosing precedence rules (for example, last-applied wins) when multiple sets are applied.
  • Manage Style Sets
    • Team-level storage with permission controls (view/apply vs edit/admin).
    • Versioning + changelog (so teams know what changed and when).
    • Deprecation controls (mark old sets as deprecated and prevent new application).
  • Sync / Update behavior
    • Optional setting per Make file:
      • Locked to a specific version (stable, reproducible)
      • Auto-update to latest approved version (keeps files aligned)
User stories
  • As a designer, I want to apply an approved style set in one click so my prototype follows system rules without manual steps.
  • As a design system owner, I want to publish a single updated style set so all new Make files use the latest guidance.
  • As an engineer, I want to trust that “semantic colors only” and other guardrails are consistently enforced across prototypes.
Acceptance criteria
  • Users can create, name, and save a Style Set from within Figma Make.
  • Users can apply a Style Set to a Make file without copy/paste.
  • Style Sets support team sharing with permissions.
  • Style Sets support versioning and rollback.
  • Applying a Style Set is reflected in the Make file’s generated artifacts (guidelines + CSS) immediately and reliably.
Impact
  • Reduced manual work and setup time per prototype.
  • Higher consistency across Make outputs.
  • Lower risk of drift from approved design system and edit guidelines.
  • Faster onboarding and more scalable governance for teams using Figma Make.
David McKay
Feb 13, 2026 5:15 AM UTC
Agree!  For context, my current workflow is…
Step 1) start a Make file….
Step 2) see the result and realize I forgot to update the .md file
Step 3) copy/paste the same markdown file I use every single time
Step 4) have it start over and try again
I would love to reuse the same .md file on every single make file by default!!
