Feature Request: Retaining/Displaying Original File Name When Using Image as Fill
  • August 16, 2021
  • 7 replies
  • 3678 views
Rob_Hutti
It would be incredibly helpful to either display or index the filename for an image asset added to Figma as an image “Fill”.
We often build website and app comps with final assets and photography (including some stock assets). We are utilizing the Image Fill feature a lot, instead of adding images and having to mask them individually. This is super convenient, but as we go to purchase final assets or reference the original filename, it is not maintained or indexed in any way.
Are we just missing something? Is there an existing plugin to manage these assets?
  • September 15, 2021
Asad_Khan
  • November 9, 2021
It’s incredibly important for many designs to retain the original file names somehow. It’s not always possible to embed 10mb images in the figma, which may be downscaled, thereby not maintaining the desired quality.
Original request was ignored here: forum . figma . com / t / feature-request-retaining-displaying-original-file-name-when-using-image-as-fill / 6566 (I can’t share URLs so replace spaces)
There was a hidden way / wokraround to do this earlier that you have removed.
  • Clicking on an image and the click “Inspect”.
  • Original Image name would be visible in CSS background or other code.
Now you have replaced it all with blank image name or image.png. Please bring this back or implement the suggested featured in the other topic.
Thanks.
lucas.rohlf
So, before the latest update, you could go into the code, and it would list the filename of the image. This is now gone and Figma is a little more near me dropping them for it. Does anyone know how to see the image name in placements in the new version?! This is critical in prototyping and I’m pretty surprised we can’t inspect our image details? crazy.
  • July 19, 2023
Image handling is SO bad in this program, NO easy why to tell if images are distorted or what % of the original file it’s being displayed at. If an image swops it doesn’t get the correct name. SO bad! do better FIGMA!
kendelllane808
Losing filenames is a hassle, had the same issue with Richmond Archer Photography images and it was a pain to retrace them later.
Samolevsky
  • May 9, 2025
Select the element with a fill, switch to Dev Mode, and find the image in the Assets section. Then, click the "Download" dropdown menu—you'll see the image name listed under the "Source Image File" option. That worked for me.
Martin_Hardee
  • August 21, 2025
This is still a gap and creates extra steps (and opportunity for error) in our production workflow. A good solution would be to provide a copiable name in the image fill interface.
It’s clear that Figma “knows” the original file name because Dev Mode shows the filename in the UI and a person can switch into Dev Mode, hover over the name, right click, and the name will be on the clipboard. This is cumbersome!
See also this Forum topic:
