Iddictive
Oct 21, 2025 8:06 PM UTC
Feature Request: Boolean / Variable Control for Flex Direction
Problem
Currently, there’s no way to bind the Flex Direction property (horizontal / vertical) to a variable or boolean condition. This makes it impossible to dynamically switch layouts inside a component using variables or modes. Designers are forced to create duplicate components or manually toggle the direction.
Proposed Solution
Allow flexDirection to be controlled via a variable or boolean property, similar to how alignment, spacing, and padding can already be managed.
Example syntax:
flexDirection = isVertical ? "VERTICAL" : "HORIZONTAL"
Expected Benefits
  1. Enables adaptive, single-source components without duplicates.
  2. Improves token-driven and responsive design workflows.
  3. Makes component logic consistent with existing variable bindings.
Priority
Medium–High — essential for scalable, adaptive design systems using Figma variables and Auto Layout.
Osama Aboelezz
Jan 30, 2026 5:39 PM UTC
Yes please! I ran into the same problem. In the themes I am creating I want to assign each theme to a layout direction but I could not find a workaround using the variables so far.
