Edit Gradient Colors via 'Selection Colors'
Constantine_Georgiadis1
There are a number of ideas related to this, but none quite capture what I think would be an obvious workflow improvement: when selecting an object with gradients, it would save a lot of time and effort if the gradient colors appear in the ‘Selection Colors’ section on the right hand panel, and are editable. (Bonus points if those colors can use swatches/variables, as others have mentioned—it would give users the ability to do a global edit!)
You can edit gradient colors in Figma by selecting the object with the gradient fill, then accessing the fill properties in the right-hand panel. From there, you can adjust the gradient stops and colors as needed. If you’re looking for a specific tutorial on how to do this, I recommend checking out some Figma tutorials on YouTube or other online resources. They often provide step-by-step guidance on how to work with gradients and other design elements in Figma.
Thanks, I am aware of all of that. I guess I may not be expressing the issue well. To try to say it a different way: it is currently a blocker to have to go into the gradient tab in the fill or stroke panel in order to edit the colors. What I am suggesting is that for a given selection, the color in each gradient stop should appear under ‘Selection colors’ in the lower right hand side, and be editable directly. This would be far better than the current MO that treats the gradients as swatches. Another issue here is that we mostly ever need brand colors in the gradient (i.e. a predefined style), not a raw hex code, so why not bring all the normal editing & variable/style workflows and abilities to gradients? Yet another reason to do it: in CSS, front end devs can use a variable (custom property) as a gradient stop. Figma should have parity.
brandonhaslegs
I think you explained it totally fine the first time. I came here to also vote for this. Surprised it’s not in Figma yet. Basically makes working with gradients unusable (or at least really annoying) in any kind of larger design system kind of way.
kiprou
  • 13 replies
  • December 5, 2024
This annoys me every day. If I edit a color via “selected colors” section, and that color is also used as a gradient stop, then 99% of the time I also want that gradient stop to change as well.
herman
  • April 7, 2025
I vibe coded a panel that replaces color stops inside of gradients and drop/inner shadows.
I need to configure some stuff to get it properly submitted but in the meantime, here it is:
it’s called “Replacer” and you can just download it from here and plonk it into your figma by using “import from manifest.json”
github.com/nimbling/Nimbling_Scripts#replacer-for-figma
Enjoy!
<edit:> submitted for review! look for “replacer” in the figma addons section near you soon!
