Convert Figma files to editable PDF forms
  • July 13, 2022
  • 5 replies
  • 6733 views
bart_van_hecke1
Hi, as I’m always on the lookout to work more efficiently, I’ve been surfing the web looking for a specific answer to my question which I haven’t found so I’m guessing I already know the answer, but here goes. I need to make an editable form in PDF which my client can open and fill in, in PDF. I can make up the form in PDF, either from scratch or from an existing PDF (exported from Figma), but the latter doesn’t work because even if I add form fields to my Figma file, Acrobat doesn’t recognize them. I found a plugin called Pitchdeck Presentation Studio which is great but it doesn’t say anything about fillable forms. I’ve tried the plugin CopyDoc Textkit which is also amazing but nothing on fillable forms. The only option I see now is to make the file in Figma without formfields, export it to PDF and add the formfields in Acrobat afterwards. Does anyone know a more effective workaround? Thx
  • August 12, 2022
Christina26
Hello @bart_van_hecke1, have you found a solution for this? I’m looking for the same thing!
fernandolins_cs
Forms in Figma are not forms at all, they’re just drawings that look like forms, so Acrobat really wouldn’t recognize them at all. You would need to use another tool to insert the actual fields over the PDF/image that you export from Figma. I’m pretty sure that Adobe Acrobat Pro (or whatever it is called nowadays) allows you to edit a file and add fields and signature markings to it.
Edit: spelling
Andreia_Quintas
Hello, im a designer and I made printables for clients such as planners, calendars and invites. how t i make the fillable parts in a specific font?
  • May 13, 2024
Hi everyone! I’m also running into the same issue. I made a PDF in Figma and I’m trying to use Adobe Acrobat to make the fields editable. I’m having a frustrating time with it at the moment. I keep getting unknown errors. Has anyone been able to find a program that ISN’T Adobe Acrobat to use?
