Change the order of exposed nested instances
  • October 10, 2022
  • 63 replies
  • 5630 views
Show first post
Julius_Klaus
  • May 16, 2024
+100000. Plus it would be nice to be able to select which properties of a nested instance are being leaked. I’m building complex design systems for clients, so they are able to quickly export customized versions of a template. But sometimes i need to restrict the client to being able to change all of the properties.
Liz_Brenner
  • May 28, 2024
10000000+ need this feature!
Iris_van_der_Looij
+100%, please make this available!
Patrick_Flanagan
+100, yes it would be so great to even pull apart the items, so that a nested item’s property could be placed anywhere, or hidden if needed.
Dan_Brown1
Replying to keep hope alive!
This needs to happen quick.
My designs look anti-UX with overrride options all over the place
Gemma_Darracott1
How many comments and votes does this need to be put on a priority backlog?
Oct 2022 this thread was started.
Gemma_Darracott1
Hello, do you have an update on this feature?
Thanks
Julius_Klaus
  • July 5, 2024
Bumping this up again.
The
  • Active Member
  • July 5, 2024
It looks like the Figma designers like the reverse order – they also make “last on top” the default state when auto layout is created - (which is unintuitive to me, expected to be like in regular layers)
tommygee
  • August 4, 2024
+1 here. this is a bit annoying.
+1 Would be very helpful if this was possible
Jup, would be really helpfull! +1
Carlos_Soares1
+1
This would be very useful indeed.
It seems messed up when I try to understand what I did when exposing nested instance. I like to tell stories with my components, you know?
Jarek_Marciniak2
+1
How is this still a thing?! When I group any other elements and use auto layout, they are displayed in a proper order. But for some reason component instance is in a reverse order - why would that make any sence? 😑
Joerian_Lazaroms
+100 Keep this alive. I would love this!
Maria_Libelt
Yes please, I need this 🙏 We use global layout component and instance slot component within it for content. This nested component is changed the most often but it is so hard to find among the nested instances because of the ordering. 😦
nigel.sham
  • October 29, 2024
Is this getting fixed or what? 2 years in and still no signs of this issue being fixed.
Inani_Sara
  • November 1, 2024
Need this please!!! +100
Jessie_Diao1
  • November 11, 2024
Need this, please +1024
Bjorn_Jarnankar
Yeah, +1 000 000. Should be easy enough to implement too and would help a ton.
Karolina_Mrozowska
I’d be so great to be able to reorder nested instances!
Mila_G
  • December 12, 2024
This is what should’ve been worked on instead of those superficial AI features…
If its too difficult/time consuming to implement the reordering of props, at least give us a ‘spotlight’ modal so we can highlight buried nested components. This way they will at least stand out when scrolling through a complex component with lots of properties.
ScottDaniels
  • December 17, 2024
+∞ Being able to organize our components by re-ordering Properties with Nested Instances would make the instances more useable and would cut down on restructuring our components over and over to get the order right.
Nick89
  • March 4, 2025
Yes, I am also shocked that this feature is not in yet, I have a very important variable that needs to be on top (even above the "normal" properties) but now it always remains at the bottom. Please make it possible for us to re-order and mix these up (regular and nested properties).
I'd also love to rename the nested instances labels (sometimes we hide the nested components by using a period in front of the name, but this makes the properties panel look messy, or is there some workaround for that which I've missed?
