Alia Atwell
May 31, 2025 12:53 AM UTC
Can't hug width and fix height
I made a form field where additional text can be shown to the right of the entry. I only need text on the right, so I didn’t wrap it in a frame like the entry field. I had to set the height of the text container to a set value so it lines up with the entry on the left. However, if I switch it to hug the contents of the text, I can’t choose to only hug the width without changing the height. I can’t use line height - it centers instead of positioning on the bottom. Obviously, I could wrap it in a frame, and then the frame can control hug separately. This is just a pain, adding more structure that I wouldn’t otherwise need if it just did what it looks like it does. It also took me a bit to realize what was happening, since I assumed that if I set hug on the width, it would only hug the width.
This was also shared here in a closed thread so I don’t think this is a just me thing. If there are two controls and I change one, it should only change that one. If I wanted to change both, I would use the buttons above.
