Ya.yo
Nov 6, 2025 6:04 PM UTC
Allow variables in parent component with variants
Hi everyone,
If I’m not mistaken, the only way to use variable logic to switch variants based on a variable mode is by creating a component, instancing it, and then connecting the variable to its properties.
For example:
I have a component called “Slider”, which contains two variants — iOS and Android.
As a designer, I’d like to use the “Slider” component and set in my file the variable "system" to iOS.
However, as a library maintainer, the only way to make this work is to create another component called “Slider”, then instance the original Slider inside it — which doesn’t make much sense.
It would be great to have a property directly in the parent component that allows variable modes to work without needing to nest components inside each other.
