Add "Delete All" dev mode annotations feature
  • February 4, 2025
  • 4 replies
  • 180 views
BenKopf_UPS
Why I need it.
  • Our designers create full specifications for components in our design system libraries and use dev mode annotations for our front end dev’s.
  • As a Figma library builder, I use those same specifications to create the actual components for our Figma libraries.
  • I copy sections from the design spec file pages and paste them into a library page to use them to create the library components.
The problem is the sections I copy into my component page are loaded with dev mode annotations that I have to delete (no, I don’t want to just turn the view off) and I have to do that one annotation at a time.
Can you please add a Delete all annotations command? Obviously a warning would be appropriate, but it would save me some time.
Thanks!
Ben
HeitorSeemann1
A feature like this would make our work way faster. I stand with you, Ben!
corpus_chase_M
same here, often we duplicate the previous design file to make changes and the previous file had detailed annotations of what has changed, but are not needed for the new file, but we still need to add new annotations so a simple hiding of annotations wouldn't suffice
daisyma
  • April 2, 2025
When I make annotations on say a button, and I copy that button elsewhere, the button with the annotation gets pasted everywhere.
Similar to “remove interactions,” it would be nice to select all of the frames that I want to remove all annotations from.
zhengpeiqin1996
