Expose/hide nested instances -> at component property level
Show first post
  • January 15, 2024
+1 Needed over here too
Bart_Vlaemynck_Belfius
+1 Really need this
Morris_Craig
I also need this feature. My customer designers get overwhelmed by all of the options some of my larger components have.
I also have trouble where large components that are composed of smaller ones will have identical properties at multiple levels. All parts of complex components all need to be set to the same platform (“Mobile”), for example. It is necessary for me to hide those platform options at the lower levels, even if I need other properties exposed at those levels.
It is too easy for one of those to get out of synch at the wrong level, which screws up the component.
Ryan_Leichty
Please oh please!
Viktor_Ostrom_Berg
We also need this functionality in our designsystem. One example is our Icons where user chooses Icon by typing its name so the name property needs to be exposed, but the other properties (size, strong, active) is not allowed to set.
Another feature that would solve this is the option to pass down property values from the top component to nested components. In that case we’d simply have an Icon name property on the top component that is passed down to the Icon component (very similar to how it would be coded in React for instance).
Would love this feature as well! I’m wanting to expose a nested property without showing all of the other properties within the sub component.
Anastasiia_Boleiko
+1 Need this feature, it’s so crucial and is a blocker in our case.
Anton_Repkin1
Very very needed for our DS. Please!
MatteoIrato
  • 6 replies
  • January 31, 2024
+1 - This would be kind of game changing to make DS users happy and avoid inconsistencies; i.e. if if they are not supposed to change a property there is no reason to show it!
Matthew_Vella
Please for this 🙏 would clean up alot of our nested architecture component structure in our DS
Matias_Greco
+1 on this! PLEEEEEASE
dennsi
  • Active Member
  • 257 replies
  • February 5, 2024
Big +1, the nested Checkbox idea from OP is nice.
Matthias
  • February 7, 2024
+1 and +6 from my entire team
cyriliously
+1 too!
In the meantime, this might be a little trick to tell users not to change the values in the final component: Just add an ⛔ or similar emoji in the name of the component. (Of course this should be then communicated.)
Mel_Bosch
  • 11 replies
  • February 9, 2024
Are there any updates yet? I neeeeeeeed this feature 😃
SteffMueller
  • 10 replies
  • February 9, 2024
+1 - This is really mandatory for quality of the property-feature. @Figma_Moderation Please push to PO, so it can be included it into next feature level.
We often don’t nest components, just because this is not possible and it’s so easy to f*ck up in property selection.
SteffMueller
  • 10 replies
  • February 9, 2024
@Josh If I understood correctly, the Issue described by OP is the same as in this topic.
Basicially It comes to “As a DS Creator I want to select the nested properties which show on a component. So that my DS Users will not be able to make mistakes in using the component.”
imho, you can merge these.
Joey_Pearlman
I’m working on a dropdown, and the expanded state is a bit overwhelming because for the nested List items it shows both the state variants and the text properties
Ideally, I’d be able to hide the nested item state variants from being exposed, because users of the system don’t need to interact with them in this case. It’s only used to change color on hover, and I should be able to make that happen secretly without users knowing how the interaction is set up.
ottovortici
+1 and +10000 for all the people who have not encountered the problem yet but one day will
This would help our DS tremendously!
Alex_Bueno
  • February 23, 2024
+1, we need this!
  • February 26, 2024
We need this. Please.
Kramp
  • 6 replies
  • February 27, 2024
make it work like components… put a . in front of the name, so it’s gets hidden in all components where it gets used.
or make it so, that I can choose which elements from the nested components, will be visible. And not just 1 checkbox, for all.
I don’t understand why this isn’t basic functionality of Figma. And wondering this with many other functionalities (like, linking to other pages from a prototype. Can already notice im looking at other software tools, because Figma is getting slow with updates, and with communications about new features that we, the community want.
Fanny_Grue
+1, this is a must have!
bogdanovjn
  • March 7, 2024
Happy Sketch users are laughing at us because they’ve been using this feature for 3 or 4 YEARS while we are just dreaming about it here… Well, let’s keep doing what we’re doing and maybe next Christmas Santa will bring the long-awaited " present". Or not…
