Remove "Show more properties" setting
  • January 29, 2025
  • 9 replies
  • 296 views
Kara_Miekina3
This is a small nit but please...i’m sure this was made for someone but can there be an option to make it so this button never appears? it adds an additional click, which is so annoying when i am trying to click between to components i am trying to compare the settings inside to.
PLUS there is nothing below it! I’m all for whitespace but minimalism that adds work is worse.
tank666
  • January 29, 2025
Uncheck the "Simplify all instances" option in the main component or component set configuration window.
Please see this Help Center article: Explore component properties.
Kara_Miekina3
  • January 29, 2025
Thank you! I had no idea that is where the issue came from! Thank you!
Jonathan_WONG1
This is still relevant for me.
I want a GLOBAL function to disable this “Show more properties” button.
I am not able to “Simplify all instances” for components that don’t belong to me.
This is really really really annoying.
Kaori_Emery1
  • September 9, 2025
I agree with Jonathan_WONG1.  The suggested solution would require me going into all components individually and turning off the simplify feature for each.  Plus, I don’t own the components in our design system so I can’t make this change.  I really never want to the extra properties to be hidden.  I use them a lot!  And it frustrates me everytime I have to press that button!  Thanks.  Just a setting to “Never show this button again” would be great.
DanilBemoli
  • September 15, 2025
Totally agree!!!
Desislava_Slavkova
Agree! Please remove! It should be an option to enable if someone needs an extra click to view more. I can’t possibly imagine why would someone prefer that especially considering there is that huge empty space right now..
JamesWillo
  • March 5, 2026
If I don’t own the master I can’t turn this off, which is really annoying.
Sometimes I need to tweak things and trying to find the correct frame to adjust the autolayout on can take ages having to click this stupid button every time.
I really don’t want to detatch the component, I just want to always see the properties!!!!
Matthias7
  • March 16, 2026
This topic is hot again. Since the release of slots this button is even more annoying, because it appears every time you want to edit a component with slots or the slot itself. Since then I have to press the button ten times per minute. Please add a setting to let me change this.
Hugo-M
  • March 19, 2026
allow users to set their settings individually please.
it’s way more usefull as a user settings, not a component setting
