I have encountered this so many times that I am wondering if there is anything that can be done. When you use a frame with an effect like a drop shadow applied within another frame, the main frame cuts off the shadows unless you add padding. If you then add padding to the main frame, the components inside falls out of the grid. I don’t know a solve but it would be great if the frames did not cut off any components with effects like a drop shadow.
Page 1 / 1
Uncheck Clip Content on the parent frame, it should help
