jili
Jan 20, 2026 12:15 PM UTC
Figma Prototype workaround: How I fixed After Delay not triggering on the first frame
I ran into a common Figma Prototype issue:
when the first animation uses After Delay (e.g. 10s auto-play for a hero carousel), it doesn’t start in Present mode unless the page is refreshed.
Small preview works. Full Present mode doesn’t.
The delay never starts, and progress indicators stay frozen.
After some testing, I realized this is because the starting frame doesn’t reliably trigger initialization, so After Delay has no real “entry point”.
My workaround
Instead of relying on time-based logic on the starting frame, I switched to event-driven triggering:
  1. On Mouse Enter (or any explicit interaction)
  2. Immediately navigate to a transition frame
  3. From that transition frame, start After Delay (10000ms)
  4. Then move to the next carousel slide
This transition frame acts as a forced “mount”, similar to a lifecycle hook.
Why this works
  • Navigate to always re-initializes the frame
  • After Delay finally gets a reliable start point
  • No manual refresh needed before demos
It’s not meant to simulate production logic, but it makes client demos smooth and predictable.
Sharing in case this saves someone else time.
Curious if others are using similar workarounds.
Melvyn Phillips
Feb 4, 2026 12:13 AM UTC
​@jili Apprieciate the heads up, was in the same situation until I understood the issue. In my case I have created a component that has a splash animation. So ideally I would not expect the user to press the screen to see the splash screen appear. But Im glad you found a work around 👍
