Download source image missing in dev mode
  • January 28, 2025
  • 5 replies
  • 261 views
Sarah_Cederberg
I’ve been noticing that my images no longer are showing the little dropdown in the asset panel that gives you the option to download the source image. Is that a bug/setting or is that functionality being removed?
Matthew Wood
  • January 30, 2025
I’m reporting the same problem
  • January 30, 2025
Hi ​@Sarah_Cederberg ​@Matthew Wood
Thanks for reaching out. I’ll check about that internally, but I believe the workaround for this is to "Option (Windows: Alt) + Click" on the image link (highlighted in green in the Code section). This should allow you to download the source image. Could you try that out?
Thanks for your patience!
Toku
Matthew Wood
  • February 5, 2025
Thanks for the reply ​@y_toku unfortunately the work around doesn’t work for me either. Not all images come up green with a hyperlink. Most are grey and thus don’t link to a source
SyNols
  • February 5, 2025
I have the same issue? Why won’t it show the original file?
SyNols
  • February 5, 2025
Fixed it!
It is because on your object you will have multiple images ontop of each other. I had 4 images below the image that was visible. Hide them or remove them. When you go back into the dev tool you will now see the image url to download.
