Fynn_M_Llyr
Jul 23, 2025 6:57 PM UTC
Why is it so hard to use libraries in Buzz, compared to other Figma products?
I’ve had 2 problems with using team libraries with Buzz so far:
  1. Adding the libraries
  2. You have to manually reapply every single style or variable that was updated in the library.
The first problem is more of a frustration that shouldn’t exist. Why change the method of adding libraries? It just makes it harder to find and use. (“Asset view” shows templates you’re using, and what would be called an “asset” in every other Figma app is now called an “insert”!? It boggles my mind that at least one entire product team thought that was a good idea. 🤯)
The second problem is a deal-breaker. For a product that’s focused on brand, it should as easy or easier to apply and update styles and variables. If there’s a button to trigger the mass application of library updates, it’s hard to find. If there is no way to trigger a mass update, that’s a huge problem, because not only do you have to keep track of what was updated, you also have to reapply all of those updated styles and variables to each affected layer. 🙄
Marinske
Aug 1, 2025 9:45 PM UTC
My sort of conclusion is to hope that Figma Buzz after the beta phase does give us what we need.
