Extended/No Expiration Personal access tokens
  • May 13, 2025
  • 18 replies
  • 725 views
shijia.me
  • before 🤗
Previously, you could generate a [no expire] token
  • now 😔
If users rely on tokens to access the figma open api, forgetting to replace expired tokens can cause serious problems.
The expiration date of the limited period will cause the figma token to no longer have usage value.
  • May 22, 2025
Hi ​@shijia.me, thanks for reaching out!
Our team is investing in security improvements to our API, so as a first step, we decided to remove the ability to create non-expiring personal access tokens.
shijia.me
  • Active Member
  • May 27, 2025
Thanks for your reply.
Please provide alternatives instead of removing this feature.
Dave Rivera
  • June 5, 2025
Hi ​@djv!
Thank you for elaborating on the situation.
Could it be possible to have a more extended option? For example, 6 months? The maintenance of updating pipelines and machines every 3 months (90 days) is too high for us. So a longer extended period for us would be great, but ideally a non-expired / yearly period would be a better option
  • June 5, 2025
Hey All, thanks for the additional feedback!
We’ve updated this topic into a feature request, and we’ve passed this along to the team for future consideration.
While this isn’t on the team’s immediate pipeline, they will be monitoring this topic to collect feedback from the community.
Robert Willemelis
I value the limitation for security purposes — but:
As I already mentioned on X, I’d really appreciate it if this limitation could be extended or removed for read-only tokens.
Idea 1:
Adjust the restriction based on the file’s visibility status — e.g. whether it’s private, public, or something in between. Introducing a third state like “confidential” or “sensitive” could help better reflect the security context.
Idea 2:
Figma could implement an AI-based check to determine whether a token might pose a security risk, depending on its scope or the sensitivity of the data it grants access to.
Idea 3:
Log the usage of the token and allow users to monitor it — for example, by seeing which hosts or users are making requests. Similar to "known device" features on other platforms, users could then confirm, “yes, that’s me.”
Idea 3a:
Allow passing a label or tag as a second argument when registering the token, to help track its usage more easily.
  • June 19, 2025
Thanks for your feedback, ​@Robert Willemelis
I’ll pass this onto our team for their consideration.
sshkalikov
  • July 7, 2025
Hi folks, please consider making it possible to create long-lived, readonly api tokens.
We need a way to periodically access Figma API from CI pipelines. With the current tokens lifetime, someone is going to have to manually update the token every 3 month, which is not a great solution, to say mildly.
Tobias Pickel
This is a showstopper for running code-connect on the ci and thus using it in a professional context.
Please let us have a workspace token or something similar that does not expire.
kelly.lawrence.thesuite
Any chance the team could make time for this in Q4 2025? This is a huge QOL issue. I really only care about the read permissions. Having to update that every 3mo is brutal.
ksn
  • September 29, 2025
Hey ​@kelly.lawrence.thesuite - I understand that this may not be the best answer, but we don’t have any available timeline we can provide or guarantee at the moment. Can confirm that it has been noted by us internally. Keep an eye on our blog -- updates are posted there (and you might find some other interesting features rolled out recently that may be worth exploring on your end): https://www.figma.com/blog/
Claire_Denning_Sage
I’m also finding the removal of this option to be a show-stopper. Please please bring it back!
anishp
  • October 29, 2025
@ksn post IPO you stop caring about devs huh :(
We basically can’t use any code connect or API features in any long lived pipeline unless we build our own agent to create new tokens at some cadence lol. I think you guys should monitor more for dropoff/usability, this is probably leading to a lot of companies being unable to use Figma’s APIs for a pretty dumb reason.
victor.nazareth
Hello, we should be able to at least have bot type accounts have a no-expiry token. By eliminating the no-expiry option, you now impose more work and convolution on maintenance of automation that takes place when using the Figma API. Please bring back the no-expiry option for bot-type accounts.
ekuersch
  • November 18, 2025
Hello, I’m also disappointed to see this feature go. We were about to launch a bunch of CI-optimized workflows for code connect, analytics, etc and the lack of a long-living token is a show stopper. Please consider bringing it back, at least for read-only permissions
Florian BURGEVIN
Hello.
We are stuck to generate automatically tokens via CI too.
Please reconsider read-only long lived tokens !
Filip Rec
  • November 27, 2025
This is absurd, it undermines all sorts of automated setups while providing no security gains whatsoever - in fact, it makes it worse by making us juggle tokens every couple of weeks. Please escalate this so that it becomes a priority.
Oliver Ullman
So infuriating how apathetic large companies get. They really couldn’t think of extending it for read-only? Figma: I know you think you’re the most important tool in the world, but if someone got READ ONLY access to mocks it’s not going to take down that company 🤣
shijia.me
  • Active Member
  • December 5, 2025
R&Ds are all focused on more "important" things, such as Figma Make. 🤣
