The problem occurs in both the desktop app and the web version
My friend has the exact same issue
I have already disabled all GPU overlays
Windows 11 pro
The same thing is happening for me :(
Same thing for me, on latest update and mac os
Same issue here on mac
Don't work! Help @figma
Same issue
same 😭
Same issue
Same here!!
Same
Same!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
same
Same
When selecting one of the objects, I want to view the distance in pixels to another object by pressing the Alt button. However, copying the element is enabled instead, rather than checking the distance in certain numbers. How can I fix this issue? I paste the screenshot.
Same - using MacOS
I just installed the latest version of Figma, and it seems that the “Measure to selection” shortcut/function doesn’t work anymore
What I’m referring to is when you select one object, then hold option key + hover over 2nd object to see the distance between the two objects - this doesn’t seem to work anymore. Instead of showing the distance, it’s showing the duplicate object icon…
Is this happening to anyone else?
Same here, not working
Heelllllllp @figma
Same issue on Windows
This was driving me nuts until I found a solution a moment ago. In my case, clearing the Figma Desktop app cache worked.
I’ve cleared it using Terminal on Mac, following the method explained in this article:
https://help.figma.com/hc/en-us/articles/22380853110551-Clear-the-Figma-desktop-app-cache
Hi there,
Thanks for flagging this! Our engineering team has released a fix for this issue. Could you please refresh your tab and try to use the shortcut again to see if this is now working?
Thanks again for bringing this to our attention, and for your patience while we worked on the fix!
Working again. Thanks.
@Junko3 thanks it is fixed
thanks for help
