Slots in components are treated as overrides and inherit styles to swapped components
  • March 25, 2025
  • 5 replies
  • 186 views
hummh
Hello,
we have a huge issue with slots in our design system. From one day to the other, without any reason our slots in components are treated like they have been overridden (e.g. border color, bg color, ...). Those styles are then inherited to swapped components. You can be 100% sure that we didn’t customise the slots and all components have been tested extensively before, so why do they now have overrides? Where do the come from? What has changed in Figma?
The only solution is to go through all components in the system and reset the slots. Honestly Figma should save time not add additional work on our shoulders …
Hope you can help us to find out what is causing this issue in Figma and how we can prevent such things in the future.
Attached you find a file showing the problem.
Thx
Harald
Sjur_Gronningsaeter
We have the same problem. When we swap to another component, the slot component styling is preserved, so we have to reset the fill and stroke manually.
amexchuckles
  • June 20, 2025
We’re also experiencing this issue. Has anyone found out the cause?
jisoo yoon
  • June 27, 2025
Same here. suffering from the same problem for weeks. Has anyone fixed this problem?
Tyler Mitchell
It would be great to hear Figma’s take on this. We are experiencing it also. One thing I think works is using a rectangle vs a frame, but that would entail a huge lift on our end to make that change.
Karl Anthoine
Same problem here. When a want to load a component in a slot, y lost a lot o styles (fill, border, ect...).
I building a design system base on Slot, and i m in big trouble now …. because it’s not working fine
It’s a major issue PLZ !!!!
