Fra123
Aug 19, 2025 12:10 PM UTC
REST API exportAsync() does not render vector/polygon with image fill
Description:
When exporting nodes with image fills using the Figma plugin API (exportAsync({ format: "SVG" }) ), the resulting SVG often contains a <pattern> that has no children, while the <image> element ends up separately in <defs>.
The exported shape is filled with fill="url(#pattern…)", but because the <pattern> is empty and doesn’t reference the <image>, nothing is rendered in most SVG viewers (Safari, Chrome, etc.).
Steps to reproduce:
  1. Create a Polygon / Vector node.
  2. Apply an image fill.
  3. Export via plugin with: await node.exportAsync({ format: "SVG" })
  4. Inspect the SVG:
    • Shape uses fill="url(#pattern0…)"
    • <pattern> is empty (<pattern …></pattern>)
    • <image> with the base64 JPEG is present in <defs>, but never referenced.
  5. Open the SVG in a browser → the shape appears invisible.
Expected result:
  • Exported shape is visible
Actual result:
  • The <pattern> is empty, causing shapes to render invisible.
  • This breaks exported SVG
Request:
Please update the SVG exporter so that image fills always produce a valid <pattern> (with an <image> child), or otherwise avoid emitting empty patterns that cause the shapes to disappear.
Aug 21, 2025 10:12 PM UTC
Hey ​@Fra123, thanks for flagging this!
I’ve passed this onto our team to investigate and work on a fix.
