Property Toggle For Mixed Values Not Showing in UI3
  • April 2, 2025
  • 19 views
William17
While using UI3, after selecting multiple instances of the same component, properties controlled by a toggle do not indicate that there are mixed values within the selection, but instead show as “all on.”
Switching back to UI2, the same selection shows the “mixed/partial” selection state for the toggle.
UI3 Toggle When Mixed Values are Within the Selection
UI2 Toggle When Mixed Values are Within the Selection
William17
  • April 2, 2025
Follow-up:
This appears to only affect the “show/hide” property on this component, as “true/false” toggles applied to other properties are accurately displayed in both UI2 and UI3 when mixed values are present.
The “filled?” and “error?” properties are true/false for variants, while the “grid gap filler?” property is show/hide.
UI3 - All Toggle Properties Mixed
UI2 - All Toggle Properties Mixed
