Personal access tokens Not working
  • February 17, 2025
  • 573 views
Ivaylo Kolev
Problem Description
I am trying to use the Figma API with a personal access token, but every request returns:
json
КопиранеРедактиране
{"status":403,"err":"Invalid token"}
I have tried the following:
  • Generated multiple new tokens.
  • Made sure to copy the entire token before leaving the page.
  • Revoked all old tokens before generating a new one.
  • Tested the token with the me endpoint:
    sh
    КопиранеРедактиране
    curl -X GET "https://api.figma.com/v1/me" -H "Authorization: Bearer MY_NEW_FIGMA_TOKEN"
    → Still getting "Invalid Token".
  • Tried with a new Figma account.
  • Tried different internet connections (Wi-Fi, Mobile Data, VPN Off).
  • Made sure the Figma file is public ("Anyone Can View").
Example Requests I Tried
1️⃣ Checking if my token is valid:
sh
КопиранеРедактиране
Expected: JSON with account details
Got: "Invalid Token"
2️⃣ Checking if my token can access my file:
sh
КопиранеРедактиране
curl -X GET "https://api.figma.com/v1/files/MY_FILE_ID" -H "Authorization: Bearer MY_NEW_FIGMA_TOKEN"
Expected: JSON with file details
  • February 18, 2025
Hey ​@Ivaylo Kolev, thanks for reaching out!
From what you’ve described, it looks like you’re using the wrong token. Be sure to use the token in the X-Figma-Token header.
The Authorization: Bearer testtokenxample is for OAuth.
Tech_AtBuck
  • March 12, 2025
Hi, doing the same and when providing X-Figma-Token, getting:
header = {'X-Figma-Token': FIGMA_PERSONAL_ACCESS_TOKEN}
'{"error":true,"status":401,"message":"OAuth token is not passed in the Bearer authorization header."}'
  • March 14, 2025
Hi ​@Tech_AtBuck ,
It might be an OAuth step issue, so but the best is getting help from our technical support team. So, could you submit a bug report detailing the steps that led to this issue? You can do so by following the link: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report
Thanks for your patience!
Toku
