Need Help About Variable
  • July 10, 2025
  • 38 views
FED_UI_UX
Hi, I have a question about a variable/component I created. I’ve set up a condition where, when the toggle or switch is turned on, the dropdown menu becomes enabled, and when the toggle or switch is turned off, the dropdown menu becomes disabled.
However, I noticed that when I turn the toggle off, the selected item in the dropdown resets to its default value. Why is this happening?
Before [Condition Switch is OFF]
After Switch to Active
After [Condition Switch is ON]
