не могу создать токен
  • June 14, 2025
  • 5 replies
  • 403 views
nixxiz
Добрый день! не могу создать токен, просто не дает сгенирировать его. Кто знает с чем это может быть свзано?
Best answer by Junko3
Hi ​@nixxiz,
I hope it's okay to reply in English. I'm not entirely sure if I've understood correctly, but are you having an issue with generating a personal access token?
If you're following our guide on Manage personal access tokens and still running into trouble, could you please share a video recording or some screenshots demonstrating the behavior? This would really help our community understand exactly what you're seeing and how we can best assist you.
  • Figmate
  • June 16, 2025
Hi ​@nixxiz,
nixxiz
  • June 16, 2025
nixxiz
  • June 16, 2025
Hi ​@nixxiz,
Hi!
When I click to generate a token, it doesn't let me make it afterwards.
  • June 16, 2025
Hey ​@nixxiz ,
Celine from the Community Support team here! I am working closely with Junko, happy to help.
From your screenshot, it looks like the scopes are currently set to “No access.” You’ll need to assign the specific scopes you want to use.
For the full list of available scopes you can assign to your personal access token, check out our developer documentation.
Hope this helps clarify!
Nellya
  • June 16, 2025
Hi!
Для пунктов Current user, Dev resources, File content, File versions, Library assets, Library content и Projects установите значение для доступа Read-only. А затем нажмите на Generate token — создать токен.
https://help-ru.tilda.cc/zero/figma-import
