My MAKE chat on the Figma site becomes increasingly laggy.
  • June 22, 2025
  • 13 replies
  • 403 views
Khoa_JAK
Experiencing lag and delays in the MAKE chat on the Figma site when expanding conversations is a common frustration, especially as the text volume increases. The issue seems to worsen over time, specifically when typing into the input field, where the system momentarily freezes before displaying the typed text.
Has anyone encountered a similar problem or found a solution to address this performance issue?
Best answer by Tom Reem
Hi ​@Khoa_JAK and everyone following along — thanks so much for your patience on this one.
Good news: Our engineering team has released a fix for the lag issue in the Figma Make chat input field. Typing should now feel much smoother and respond as expected. ✅
💡 If you're still experiencing any trouble, try giving the tab a quick refresh and let us know how things are running on your end. We’d love to hear if the experience has improved!
Tom Reem
  • Figmate
  • 609 replies
  • June 22, 2025
Hi ​@Khoa_JAK — welcome to Figma Forum, and thanks for sharing your experience with Figma Make so far!
Sorry to hear about the lag — definitely sounds frustrating. I’d like to pass more details to the product team so they can dig in. Could you share a bit more context about your workflow and what’s happening leading up to the freezing? For example, what kind of prompts and how would you describe the text volume are you working with? Also, let me know if this is happening in the web app, desktop app, or both. That’ll help us narrow things down.
Our Technical Quality team can also take a closer look at the specific file you’re working in. You can get that started by filling out this form and including:
  • a link to the file where this is happening
  • edit access granted to support-share@figma.com for the impacted file
  • a screen recording showing the issue in action.
Again, appreciate you flagging this. We’ll keep watch for replies and updates here. 🙏🏻
Wawa
  • 16 replies
  • June 22, 2025
Yup I have the same issue, there is like a 10 second delay between typing, and the words appearing.
Tom Reem
  • Figmate
  • 609 replies
  • June 23, 2025
Hey ​@Khoa_JAK and ​@Wawa — thank you again for raising this.
I’m returning with an update after checking in with the engineering team. They’re aware of this issue and are actively working on a resolution. While I don’t have a specific timeline to share just yet, here are a couple of troubleshooting tips that may keep you moving forward in the meantime:
  • Try drafting your prompt in notepad first, then copy and paste it into the Make textbox.
  • Duplicating the file and continuing from there has helped some users as a short-term solution.
Appreciate your patience — we’ll be in touch with more developments as soon as possible, and keep me posted on how it’s going!
Khoa_JAK
  • June 23, 2025
Update:
Thank you for your response.
For your information, the Duplicate solution does not work for me.
I will wait for the update.
@Tom Reem I’m okey to share the detail.
  1. I start with a english prompt mix with some vietnamese.
  2. The initial prompts didn't have any issues at all; the problem, in my opinion, only started around version 7 or 8 (when the density of text in chats or code began to increase). I guess the main issue lies in the chat section.
  3. My process is that I ask ChatGPT to write a logical prompt based on my idea, and then I copy it from ChatGPT into Figma
  4. Currently, it's version 38, and I can only write externally and then copy it into Make's input instead of typing directly, as it's become too laggy and delayed.
  5. I've also filled out the Technical Quality form as you provided. Thank you!
Tom Reem
  • Figmate
  • 609 replies
  • June 23, 2025
Thanks so much, ​@Khoa_JAK — this added context is super helpful. I’m passing it along to the right team so we can take a closer look. Will keep you posted with any updates!
Wawa
  • 16 replies
  • June 23, 2025
Thanks Tom, for me it started happening around iteration 300, I am currently at version 580 and it has noticeable gotten slower
Leith
  • July 2, 2025
Hi Team, Just thought I would add to this, my make chat window has also become very lagging in two of my projects that have versions over 100 versions, it seemed one started even maybe around version 80 or so. Yes it still all works and buld but the input lag on the text window is very noticeable.
the only fix is to type in a notepad first and then paste it, as I have found no way to get around it.
Tom Reem
  • Figmate
  • 609 replies
  • July 7, 2025
Leith
  • July 8, 2025
Thanks Tom,
So far looks like the lag has been sorted, will report back if occurs again.
And thanks for the fast resolution on this.
Cheers
Leith
Tom Reem
  • Figmate
  • 609 replies
  • July 14, 2025
Really appreciate you closing the loop on this, ​@Leith. 🙌🏻 If anything else crops up or you'd like a second set of eyes on something, we're always here to help. 💯
Paul_Ruda
  • 4 replies
  • July 22, 2025
The Make chat interface is extremely slow for me. The interface has stopped taking inputs. I am at version 373 of my app, which has required a lot of patience as the longer the chat thread got (and the more developed the app was), the more the lag issues increased. Now I am unable to get the interface to do anything beyond giving me the error that something went wrong:
This message I typed was very delayed while typing and will result in another Something went wrong message. So I’m stuck. The app is a larger one, with a supabase backend and some shortcut keys built into it for dev feedback so it’s possible one of those details is contributing, but to be honest the lags started many versions ago and have recently gotten much worse. Any help you could offer would be much appreciated as I have hit a wall trying to troubleshoot.
If I start a new app, there is no issue with the lag, but I believe it would return with more back and forth with prompts before long. I’m looking forward to working with you on a resolution as this is still a new product. Thanks. Loving Make! - Paul
Paul_Ruda
  • 4 replies
  • July 22, 2025
Incidentally. The app itself is running and is fairly responsive in the preview, it seems to be the Claude chat interface that is struggling.
Tom Reem
  • Figmate
  • 609 replies
  • August 5, 2025
Hey ​@Paul_Ruda — thanks for sharing your experience as well! I circled back on a few open threads, and it looks like we were able to land on a conclusion in this post: Figma Make: AI response is not working after 2 days of usage. 🙏🏻
For anyone following along here, I also wanted to highlight a couple of resources that might be helpful when working with Figma Make:
Appreciate your patience while we continue iterating and improving — feel free to keep us posted on how things go. 💫
