Bruce Pauker
Feb 16, 2026 1:21 PM UTC
MCP get_design_context drops Code Connect snippets as soon as a component becomes a Variant set (Component Set)
Hi Figma team / community,
I’m seeing a consistent, reproducible issue with Figma MCP, specifically the get_design_context tool, when a component changes from a single component to a Component Set (2+ variants).
Summary
  • With one variant only, get_design_context returns a full React tree and correctly includes CodeConnectSnippet blocks for nested components connected via Code Connect.
  • As soon as I add a second variant (making it a Component Set), get_design_context changes behavior:
    • it generates the expected union type for the variant property (e.g. type?: "..." | "...")
    • but the returned JSX collapses to an almost empty wrapper (often a self-closing <div ... />) and drops the nested children / Code Connect snippets.
This happens even if the component contains only a single nested item (so it’s not related to having many list items).
Expected behavior
For a Component Set, I expect get_design_context to still produce a meaningful snippet for the selected variant/instance and preserve Code Connect snippets for nested mapped components (or at least provide a consistent per-variant output).
Actual behavior (examples)
Case A — Single variant (works)
get_design_context returns a full structure with nested snippets, e.g.:
function ContextualMenuList({ className }: { className?: string }) {
return (
<div className={className || ""} data-name="contextual-menu / list">
<div data-name="type=toggle & delete">
<CodeConnectSnippet data-name="item-01" data-snippet-language="React">
<AthContextualMenuItem
label="Label"
state="enabled"
showToggleButton
showDeleteButton
deleteButtonProps={{ color: "neutral", size: "small", type: "ghost", startIcon: "delete_outline" }}
</CodeConnectSnippet>
{/* ... item-02, item-03, etc. */}
</div>
</div>
Case B — Two or more variants (breaks)
As soon as there are multiple variants, the output becomes:
type ContextualMenuListProps = {
className?: string;
type?: "status" | "toggle & delete" | "toggle & status" | "toggle";
function ContextualMenuList({ className, type = "toggle & delete" }: ContextualMenuListProps) {
return (
<div
className={className || "content-stretch flex ..."}
data-node-id="11261:1931"
=> The wrapper is self-closing (<div ... />) and all children / nested instances / CodeConnectSnippet blocks are gone.
Additional observation: “toggle button” area renders as raw generated code, while “delete button” renders via Code Connect
In another component, within the same get_design_context output, I see a surprising mix:
  • The toggle button area is rendered as pure generated code with exported SVG assets:
{showToggleButton && (
<div data-name="toggle-button">
<div data-name="icon">
<img src="http://localhost:3845/assets/...svg" />
</div>
</div>
  • Meanwhile the delete-button area correctly renders as a Code Connect snippet:
<CodeConnectSnippet data-name="delete-button" data-snippet-language="React">
<AthButton color="neutral" size="small" type="ghost" startIcon="delete_outline" />
I even tried copying/pasting the exact working delete-button content into the toggle-button area. The toggle-button area still renders as raw generated code (no CodeConnectSnippet), which suggests Code Connect resolution depends on the node/slot context (or variant/component-set resolution), not only on the nested component itself.
Steps to reproduce
  1. Create a component with one variant and nested instances that have Code Connect mappings.
  2. Run MCP get_design_context on an instance:
    • Full tree + nested CodeConnectSnippet output (expected).
  3. Add a second variant (component becomes a Component Set).
  4. Run MCP get_design_context on an instance/variant:
    • Output collapses to a wrapper and drops children/snippets.
Environment
  • Tool: Figma MCP — get_design_context
  • Output: React
  • Code Connect is configured and works in the single-variant case (and for some nested nodes).
Thanks!
Bruce
