Manually edit a figma MAKE file?
  • July 17, 2025
  • 2706 views
Ankit Ujjwal
I have created a figma MAKE file which requires some changes that can be done very easily manually. I am not able to find a way to edit the UI generated by figma MAKE file
SergeantSass
  • July 24, 2025
I have the same question. I asked the Ai and in its reasoning tab I could see that it’s apparently not possible. This is what it said:
“The user seems to have a misunderstanding about the workflow. Figma Make allows you to:
  1. Import designs FROM Figma
  2. Create interactive web applications based on those designs
  3. Export/save the web application code
But it doesn't save back TO Figma as an editable design file. The character sheet they've created is a functional React web application, not a Figma design.
I should clarify this for them and explain what their options actually are for preserving and working with this current version.”
But then I ran out of prompts for the day, so it never actually answered my question
SergeantSass
  • July 24, 2025
Turns out you can edit, but only the CSS code, which is cumbersome to say the least
