Issue publishing font update in component library
  • February 6, 2025
  • 22 views
Mat Hebert
I am attempting to publish 2 font updates in my text styles. All I did was change the font from Inter to DM Sans for 2 items and it will not publish. These are only being used inside the Button component at the moment.
  • 2544 replies
  • February 10, 2025
Hi there,
Thanks for reaching out. Do you have any “Invalid assets”? If so, you might be seeing them in the publish modal. Typically, invalid assets prevent the library from being published, so that could be the issue. If that’s the case, you’ll need to resolve these before you can publish.
Could you check if you have invalid assets? If the issue persists, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Please make sure you use the email associated with your Figma account, include links to the file in question, and share access with support-share@figma.com. Don’t worry, inviting us to view your file won’t impact your billing.
Toku
