Intermittent Line Height Decrease When Clicking on Text
  • January 24, 2025
  • 8 replies
  • 382 views
Sonia14
Hello, I am a user of Figma based in South Korea.
Over the past week, several designers on our design team have been experiencing an intermittent issue where the line height of text decreases. However, this issue has not yet been resolved, and I am curious if other users are facing the same problem.
We are using the font 'Noto Sans KR' for our text styles. When we double-click on a text box that is using this font to enter edit mode, we notice that the line height suddenly decreases.
After uninstalling and reinstalling the font on our computers, or overwriting the font file and then accessing Figma again, the text with reduced line height returns to its original line height when clicked. However, this solution is temporary, as the same issue can occur again the next day.
This phenomenon appears intermittently among designers, and some designers have not yet experienced this issue.
I have attached example video below. This problem is causing significant inconvenience in our work, and we sincerely hope for a prompt resolution.
Nancy_Yen
  • January 24, 2025
The font I used is 'Noto San TC' , and the same problem occurred 😢
Rena Hamada
  • February 4, 2025
I use 'Noto San JP' , and the same problem occurred 😢😢😢
titled Un
  • February 5, 2025
저도 같은 현상을 겪고 있습니다… 혹시 해결하셨나요?ㅠㅠ
ksn
  • February 6, 2025
Hey all - according to everyone’s reports here, it looks like the common denominator is the noto sans font. I’ve filed a bug ticket to see if there are issues being triggered when using that specific font family. Will update when I hear more.
Sonia14
  • March 5, 2025
글 올리고 잊고 있다가 방금 들어와봤는데...일시적이지만 해결방법이 있긴합니다.
  1. 피그마를 종료한다
  2. 문제가 발생하는 글꼴파일을 덮어씌우거나 지우고 다시 설치한다
    • 윈도우 환경에서는 폰트파일을 덮어씌우기만 해도 해결됐습니다.
    • 맥을 사용하시는 디자이너분들은 지웠다 다시 설치하셨다고 하시네요
  3. 피그마를 열어 행간이 줄어든 텍스트 박스들을 다시 클릭한다.
  4. 행간이 돌아오면 성공
위의 과정대로 실시하면 일시적으로는 문제가 해결되긴 했습니다만,
다시 문제가 발생해서 완벽한 해결책은 아닙니다.
ksn
  • April 25, 2025
Hiya everyone - I know it’s been a while, but I wanted to update you on the status of the bug report I originally filed.
First, thank you ​@Sonia14 for offering up some suggestions - much appreciated!
Lastly, this is not considered a bug, but expected behavior at this time, because of the recent font update. I hope this was helpful to at least provide closure.
Sonia14
  • May 12, 2025
Hello! ​@ksn
Thanks for getting back to us and letting us know the cause of the issue, even though it took a little while.
Upon understanding that the problem stemmed from the line height information of the Noto Sans font changing due to the font update, we addressed it by adjusting our existing font styles.
For those who might be encountering the same problem, we'd like to share how we solved it. It's a straightforward approach, but hopefully useful for reference:
_____
Previously, we were using 'auto' line height in our Figma font styles.
We confirmed that in our actual development environment, line-height: 1.4 was applied to all fonts. So, we changed the line height for all Figma font styles to '140%'.
Publishing the styles with 140% line height allowed us to revert the line height to be similar to how it was before the font update.
_____
Hope this helps!
@Nancy_Yen ​@Rena Hamada ​@titled Un
ksn
  • May 12, 2025
Thank you!! Super appreciate you sharing how you were able to address this. I’m going to highlight your post to help grab attention for those who are facing similar trouble/confusion.
