Inconsistent selection behavior when dragging to select items
  • June 14, 2025
  • 82 views
Mara Kosac
I'm experiencing an issue with the selection tool in Figma. When I try to click and drag to select multiple items on the canvas, it often fails to work properly. Sometimes it only selects some of the items within the selection box, and other times it doesn't select anything at all even though I'm definitely dragging over layers. And then I have to select them one by one, the only way it works.
Best answer by Celine_
Hi ​@Mara Kosac , thanks for flagging this, and I’m sorry for the trouble you’ve been experiencing.
Our engineering team has rolled out a fix. When you have a moment, could you please try restarting or refreshing Figma to see if everything’s working as expected now? Thank you!
  • June 16, 2025
Mara Kosac
  • June 16, 2025
It’s working now, thank you!
  • June 17, 2025
Yay! Thanks for letting me know. I’ve gone ahead and marked as solved the topic here.
Thank you!
