I found an issue when I subtract rectangle with radius 40 from another rectangle with no radius
  • February 18, 2025
  • 43 views
AloloGamer
First rectangle with radius 40
Second rectangle with radius 0
Result of subtraction
Dear Figma team, I hope you are doing well, I have found an issue when I have tried to subtract rectangle with radius 40 with another rectangle with radius 0, I expect the subtraction will be with the same radius “40” but I found one edge with 40 radius and the other one with 0 radius.
Another notice when I rotate the rectangle “with radius 40” 180 degree and then I subtract it from the rectangle “with radius 0” the result of subtraction was the two edges with radius 0.
Rotate rectangle 180 degree
Result of subtraction after rotation
I hope guys that you fix this problem.
Thanks
AloloGamer
  • February 18, 2025
Hey ​@AloloGamer, thanks for flagging this!
We’ve passed this over to the team to investigate and work on a fix.
We haven’t be able to reproduce this issue yet. What OS are you using? Is this happening both in browser and using the desktop app? Are you able to share a screen recording to help guide the team in reproducing the issue?
