Send or import multiple frames to Figma Make
  • October 15, 2025
  • 7 replies
  • 1132 views
Martyn_Bowis
How to send or import multiple frames to Figma Make from a Figma Design file?
It seems that it is possible to send one frame to Figma Make and it will create a new Figma Make file from that one frame. However, when multiple frames are selected (e.g. different screens of the same prototype) then the “Send to Figma Make” option disappears.
I can also see an option to Import from Figma, but the interface for this is terrible when you have thousands of Figma Design files in your enterprise and they each have multiple components within them. Worse still, it seems you cannot import a frame, only components that have been published.
Is there something I could be doing differently that would make it easier to import multiple frames from a Figma Design file into the same Figma Make file?
As a designer
I want to be able to import multiple frames into Figma Make
So that I have an interactive prototype of what I have designed
Given I have multiple screens designed
When I select those multiple screens
Then they are all able to be imported into Figma Make
simon-zuno
  • October 22, 2025
+1
  • Figmate
  • October 23, 2025
Hi ​@Martyn_Bowis ,
I understand that you’d like to select multiple frames in a Figma Design file and use the “Send to Figma Make” option.
I tested this on my end, and it appears that I can select up to three frames for the “Send to Figma Make” . This seems to match the current limit for attachments per prompt, so it may be an existing limitation.
You can find more information here: Attach designs and images to a prompt
Thanks for taking the time to write in and share your experience.
I understand that you’d like the ability to select and send more frames at once to Figma Make, and I’ll pass this feedback along to our team for consideration.
James Nagel
  • November 4, 2025
It would be great to expand this functionality to better inform a Make prompt. We have a high fidelity Figma Design file that would give good direction to the Make Agent, but I end up sequentially prompting Make frame by frame to get something close to the Figma Design file.
Better transfer from Figma Design and FigJam may be a heavy lift initially, from an AI credits perspective, but I’d expect the AI resources needed would overall be reduced for the end deliverable compared to the long tail of prompts to get the Make prototype to where the user wants it.
Thank you!
  • November 4, 2025
Thanks for the additional feedback, ​@James Nagel
We’ve updated this topic and changed it into a feature request to gauge overall interest from the community. We’ll continue to monitor and pass feedback from this thread onto our Make team for future consideration.
Thawan Jeerathanasit
+1 for this. When creating complex prototype if we can import multiple frames and tell Figma Make to connect them, it would be great
wordpictures
  • November 19, 2025
+100 on this. It would also be wonderful to attach a user flow and then have Figma Make intelligently do the rest of the heavy lifting. :)
Sanjay Reddy
  • March 25, 2026
I’m able to upload the entire user flow in a click!
