Yair_Zaks1
Jul 19, 2025 7:56 AM UTC
Glass Effect API missing light reflection border when applied via plugin
When applying the Glass effect via my plugin using Figma's Glass Effect API, the light reflection border that appears around elements when applying the effect directly through Figma's UI is missing. This creates inconsistency between plugin-applied and manually-applied Glass effects, even when using identical parameters.
Steps to Reproduce
  1. Create a frame in Figma
  2. Apply Glass effect directly via Figma's Effect panel - note the light reflection border around the element
  3. Clear the effect
  4. Apply the same Glass effect with identical parameters via the Liquid Glass plugin
  5. Observe that the light reflection border is missing in the plugin-applied version
Expected Behavior
The Glass effect applied via the plugin API should be visually identical to the same effect applied manually through Figma's UI, including the light reflection border.
Actual Behavior
The Glass effect applied via the plugin is missing the light reflection border that's visible when applying the effect manually, despite using identical parameters (light angle, intensity, refraction, depth, dispersion, and frost).
Technical Details
  • I've reviewed the Glass Effect API documentation thoroughly and found no parameter to control this border reflection
  • All other aspects of the effect (refraction, etc.) appear to be working correctly
  • The issue is consistent across different element types (frames, components, etc.)
  • Plugin is using the latest version of Figma's API
Questions
  1. Is there an undocumented parameter needed to enable the light reflection border?
  2. Is this a known limitation of the Glass Effect API?
  3. Can this be addressed in a future API update to ensure consistency between plugin-applied and manually-applied effects?
Additional Information
I've attached a screenshot showing the difference between the plugin-applied effect (left) and the manually-applied effect (right). The light reflection border is clearly visible in the right example but missing in the left.
lesliwanigarathne1980
Jul 19, 2025 9:32 AM UTC
Thanks for pointing this out! A clear breakdown like this really helps. Maybe try manually adjusting the layer’s blending mode or adding an outer glow in the plugin as a temporary fix. Hopefully the Figma team can address this API limitation soon.
Yair_Zaks1
Jul 20, 2025 1:52 PM UTC
Thanks ​@lesliwanigarathne1980, I will wait until Figma fix this API call issue, I don’t want to fake the effect (again haha)
Yair_Zaks1
Nov 4, 2025 12:56 PM UTC
​Figma? Someone? =)
zewu
Apr 13, 2026 5:08 AM UTC
Thanks for sharing the case. Running into similar issues using Figma MCP to produce the glass effects: the light reflection border is missing despite the value seems to be proper. Comment for more attention
Yair_Zaks1
Jun 16, 2026 1:04 PM UTC
Running into similar issues using Figma MCP to produce the glass effects: the light reflection border is missing despite the value seems to be proper. Comment for more attention guys =)
Jaycee Lewis
Jun 29, 2026 8:27 PM UTC
Hey hey y'all 🙌 Thanks for the original post, and for circling back and keeping it alive ​@Yair_Zaks1
I’d like to get us more info so we can get it on to the team that owns these endpoints. Would you be up for putting together a fresh 2026 reproduction case with me?
Here's what would make the strongest case (IMO):
A short screen recording is the single most useful thing — apply Glass through the Effects panel, then clear it and re-apply the same settings through your plugin, all in one take so nothing moves in between. That captures the difference far better than stills.
Alongside the video, if you can include:
  • A couple of before-and-after screenshots (UI-applied vs plugin-applied), framed identically
  • Your operating system (OS) and exact Figma version (Help > About Figma — this thread goes back a ways and a lot has shipped since)
  • The exact Glass values you're using (light angle and intensity, refraction, depth, dispersion, etc)
  • Which plugin you're applying with
One thing that got me in my quick test — Glass refracts whatever's behind the element, so put something with detail behind your shape, like a photo or some colorful layers, and give the shape a low or no fill opacity. We want to try to not muddy the comparison.
No promises on turnaround once it's there, but a clean, current reproduction file is genuinely our best shot. Talk soon! — Jaycee
Yair_Zaks1
Jul 1, 2026 9:35 AM UTC
Hi ​@Jaycee Lewis, thanks for your reply.
I tested it 2 weeks ago (before your reply) and it didn’t work (Figma effect was adding the border while plugins/mcp’s didn’t - like in the image and first video “Testing old versions” attached ):
But now, after testing it today, I see the plugin started applying the border correctly (image + video attached):
Nothing changed on my end (didn’t touch the code of it for a few weeks already).
So it looks like it was fixed somehow and we are ok now, haha.
Maybe ​@zewu can test it once again with the MCP and let us know if it was fixed also there.
More data:
Plugin Link:
https://www.figma.com/community/plugin/1514712823311805488/liquid-glass
My Mac info
My Figma info
Glass effect panel (values were always the same - I made Figma’s default the plugin’s default too):
Any idea how it was fixed? In my plugin it just started working correctly now haha
Of course I´m available also for a zoom/teams meeting if more info / tests needed.
Thanks in advance!
Yair
Isoftmarts 01
Jul 1, 2026 9:45 AM UTC
This looks like a limitation of the current Glass Effect API rather than something you’re missing. Figma often applies certain visual enhancements in the UI layer that aren’t fully exposed through the plugin API, and the light reflection border seems to be one of those subtle details.
If all your parameters match and other properties are rendering correctly, it’s likely not an implementation issue on your side. Hopefully, Figma will expose more control in future updates for consistency.
I’ve seen similar gaps in tools before—teams like Isoftmarts usually handle this by creating custom visual layers to replicate missing effects when APIs fall short.
Jaycee Lewis
Jul 1, 2026 7:05 PM UTC
Hey ​@Yair_Zaks1 👋 Amazing. I’m glad to hear it is working. The team let me know they were aware of what you raised. Glad to see it’s out there now. If you notice any other strangeness, please feel free to tag me and I’ll take a look. And to your last question — I can’t say for sure 😉 but I have a feeling your advocacy played a big part. Keep being awesome. Thanks again! — Jaycee
