File name field missing during export
  • August 12, 2025
  • 46 views
lorinc.kiss
In some cases, the export dialog is not showing the field for file name on OSX (I have tested the same on Windows, and the issue is not present there). I have observed the behaviour consistently every time.
How to reproduce:
  • Create a section with a name including ‘/’ (such as “Products list / Filtered”)
  • Create a section inside this with an empty name
    The reason for the desire to not give it a name is simple: when the section is exported, the PNG actually includes the section name in the top left, which is undesirable in my specific case
  • Place any frame and/or element inside this section
  • When you are trying to export the inner section (the unnamed one) to PNG, the export dialog is missing the file name field, which is unfortunate since “.png” is not a valid name, so Figma is unable to complete the export.
The issue is immediately solved if the ‘/’ is removed from the name of the outer section.
I’m not sure if this is a bug or a feature gone wrong, but since the same doesn’t happen on Windows, I suspect the former.
  • Figmate
  • August 13, 2025
Hi ​@lorinc.kiss,
I tried to reproduce this on my end using the Figma desktop app on macOS, and I was able to see the same issue.
After clicking Export and then Save in the dialog, I received the same error message you mentioned.
Interestingly, when testing in the browser, the export triggers a download of an Untitled.zip file, which contains an empty folder named after the outer section (“Product list”).
I understand how important this export flow is to your workflow, especially when avoiding section labels in the exported PNG. I'll go ahead and file a report for our team to review.
While we can’t promise a timeline for a fix, we truly appreciate you bringing this to our attention — and especially for flagging it with such clear repro steps.
