Dear Figma Team and Community, I'm encountering an issue preventing the Flutter plugin from working.
When attempting to use the plugin, I receive the following error: "An error occurred while loading the plugin environment"
When I look at the developer tools I see that requests to the Figma API are being blocked with 403 errors. Specifically, these endpoints are affected:
`https://www.figma.com/api/plugins`
`https://www.figma.com/api/widgets`
Both requests return a 403 "Request blocked" error generated by CloudFront.
Example CloudFront Request IDs are:
B0KxQIDEzIcouCe83YY6a8EZP7mRysS8K1X2QB86eH2s-VffQAeIaQ==
9UycUOv8GwzvNwUBy53u0ZyepNoQF_pRriuz-AOI0OUmFxgErda7iw==
Crucially, I am operating behind a proxy server. This is likely a contributing factor, but I need guidance on how to configure my environment (or the plugin) to work correctly. The CloudFront error suggests potential traffic overload or configuration issues, but given the proxy, I suspect the issue is related to how the plugin/Figma API handles proxied connections.
Figma Plugin/Widget API Access Blocked (403 Errors) - "An error occurred while loading the plugin environment" in Flutter Plugin
