While using Figma Make, it will occasionally stop processing midway through completing a prompt. The updates stop, but there is no error, so it’s not very clear whether the work has been completed or not. Sometimes if I move onto the next prompt, it will finish the changes before moving on, or I found if I instruct it to “complete the update,” it will pick back up where it left off. This is typically for more involved prompts. Easy enough to work around, but it needs better messaging and/or error recovery.
Hey
That said, we’re continually working to improve the experience. This resource may help you get the most out of prompt-to-code: 8 essential tips for using Figma Make.
If the issue keeps popping up (especially without an error message), we’d love to learn more about your setup. When you have a moment, could you fill out this quick form so our Technical Quality team can take a closer look? Please include:
- a link to the file where this is happening
- ‘can edit’ access granted to support-share@figma.com for the impacted file
- a screen recording showing the issue in action.
This will help us reproduce the behavior more directly. Thanks again for flagging and keep us posted on how it goes!
