Figma Make error for the past two days
  • December 4, 2025
  • 5 replies
  • 393 views
Prince Kumi-Frimpong
I’ve been getting a persistent error in Figma Make for the past three days. It was working fine before, and I’m currently on app version 326.
I’ve tried the common fixes suggested by other users, including duplicating the file, testing new prompts, and restarting the app, but none of these have worked.
I’ve also opened an issue and granted access to share@figma.com, but the invite hasn’t been accepted yet.
This is affecting my workflow, so I’d appreciate your support in resolving it.
Screenshot of the error has been attached
Best answer by Celine_
Hey there, Celine from Figma here! Thanks for flagging it and sorry for the disruption.
The “couldn’t reach server” error is occurring more often due to high demand and capacity constraints with the Gemini 3 Pro model.
Our engineering team is working closely with the model provider to improve stability.
In the meantime, you’re right, turning off Gemini Pro resolves the issue.
For anyone else experiencing the same problem, we recommend switching back to the default model by disabling "Experiment with AI models" in your Make file’s Experimental Models settings.
Thanks for your patience!
Resolved after toggling off Gemini pro.
  • December 4, 2025
Luchtbakker
  • December 4, 2025
I frequently encounter two problems when using Beta AI. Especially when questions are somewhat larger, or the project is already quite extensive, Gemini is completely unusable.
Is there a solution for this? Because Gemini is clearly better at programming than the current Claude integration.
  • December 4, 2025
Hey ​@Luchtbakker , thanks for your feedback. I’ve merged your topic with a similar one. Please check my previous reply in this thread, thank you!
And E7
  • January 19, 2026
I have the default model. Gemini isn't even enabled. As soon as I switched to the Pro plan, everything started working. I bought a Fig for work. And now I'm losing money because of this problem. It's been down for two days. Tech support is silent.
