Figma Make doesn't show anything, just a blank canvas.
  • July 28, 2025
  • 7 replies
  • 817 views
v0ort
Hi I’ve tried three different prompts within figma make but when it’s done doing it’s magic the preview area isn’t showing anything. Just a blank page. However when I open the code editor I do see code. Am I doing something wrong here or am I missing something?
Best answer by Junko3
Hi ​@v0ort ,
As ​@Shawn_Wang1 mentioned, this could be related to your company's network settings. Sometimes, corporate networks have strict security filters that may block certain features in Figma.
Here are a few things you can try:
  • Create a new Figma Make file to see if the issue still occurs.
    • If the new file works fine:  The issue may be specific to the original file.
    • If the issue persists:  It’s likely something with your network or account setup.
For more details, this Help Center article explains how to adjust network settings to ensure Figma works properly: Adjust your network settings
You might want to share it with your IT team so they can check if anything is being blocked.
Shawn_Wang1
  • July 29, 2025
Try to see if it’s blocked by DNS Filter. Was able to resolve this by contacting my admin
  • Figmate
  • July 30, 2025
Hi ​@v0ort ,
Jackie_Curry
  • July 30, 2025
I have the same thing happening but it is only for one project, so it is not my company blocking it.
Blake Ledden
  • July 30, 2025
This is similar to the issue I detailed in a separate thread in this same “Report a problem” forum. Also seems to be just for one project, but it re-occurs on any copy of the project I make as well. Any chance there is a rollback y’all need to do ​@Junko3? I am on my own home network and definitely not experiencing DNS issues AFAICT.
  • Figmate
  • July 30, 2025
Hi there,
Thanks for reporting this!
To help our team investigate further, if you're open to it, please fill out this secure form:  https://figma.bot/submitreport .
In the form, kindly include the URL of the file where you're experiencing the issue and grant edit access to support-share@figma.com. (Rest assured, granting this access will not affect your billing.)
This will allow us to reproduce the issue and investigate it more effectively.
Thanks for your help!
v0ort
  • August 5, 2025
Update:
I tried to open the same files in Chrome on my private macbook and everything seems to work so I guess it’s the companies restrictions that are blocking it. I will contact my IT department to try and fix it.
Thank you!
Laszlo
  • November 19, 2025
I had the same issue and what solved it is the following:
I prompted “The preview screen is blank”
I got back:
“Let me check the App.tsx file to see if we're properly importing and using the component:Now the preview should display the product page ….”
And it shows indeed...
