naveeny
Jan 26, 2026 4:16 PM UTC
Figma Desktop MCP: get_metadata returns instruction text only and get_design_context aborts without data (Stable + Beta, /sse and /mcp)
When using the Figma Desktop MCP server with an MCP client (Cursor IDE), the core design extraction tools get_metadata and get_design_context do not return any usable design data, despite the server being reachable, tools being discovered, and parameters being validated successfully.
Environment:
  • OS: macOS
  • Figma Desktop Stable: 125.11.6
  • Figma Desktop Beta: 126.1.0
  • MCP Transport tested: /sse and /mcp
  • MCP Client: Cursor IDE
  • MCP Server URL: http://127.0.0.1:3845/sse (also tested with /mcp)
Observed Behavior:
  • The MCP server starts correctly and is reachable.
  • Cursor successfully connects to the server, enumerates available tools, and validates tool arguments.
  • Calls to get_metadata with a valid explicit nodeId consistently return only an instructional string (e.g., “IMPORTANT: After you call this tool, you MUST call get_design_context…”) instead of the expected XML metadata (node hierarchy, bounds, layout, etc.).
  • Calls to get_design_context with the same valid explicit nodeId consistently terminate with Error: Aborted, without returning any design context payload, partial output, or actionable error information.
  • This behavior occurs even when:
    • Passing an explicit valid nodeId
    • Using minimal parameters (nodeId only)
    • Using schema-correct parameters (clientFrameworks and clientLanguages as strings)
    • Testing both Figma Desktop Stable and Beta
    • Testing both /sse and /mcp transports
Expected Behavior:
  • get_metadata should return structured XML metadata describing the selected node (type, hierarchy, bounds, layout, etc.).
  • get_design_context should return a design context payload (layout, spacing, typography, colors, and other design properties), or at minimum return a clear, actionable error if generation fails.
Why this appears to be a bug:
  • The tools are callable and pass schema validation, but return no data.
  • The instructional strings appear to be fallback guidance text rather than actual tool results.
  • The Error: Aborted response from get_design_context indicates a server-side termination after the request is accepted.
  • The issue is reproducible across Figma Desktop versions, transports, and parameter combinations, strongly indicating a server-side Figma Desktop MCP implementation issue, not a client or configuration problem.
Impact:
This prevents any design-to-code or metadata extraction workflows using the Figma Desktop MCP server, leaving get_screenshot as the only functional tool and forcing visual inference instead of structured design data.
RonvdzCM
Jan 28, 2026 6:32 AM UTC
I am also experiencing the same issue an error on get_metadata when using the connector in Claude. Is there any fix reported?
刘相成
Jan 30, 2026 1:10 PM UTC
me too
3flipjump
Feb 4, 2026 11:40 AM UTC
Same to me
T_T
RunProf_Development_Email
Feb 12, 2026 8:47 AM UTC
Me to, No solution yet ??
ksn
Feb 16, 2026 4:19 PM UTC
Hi all - I checked in with the engineering team about this, and they believe this could be a problem with Cursor when it comes to some cases in cursor-auto mode.
They’ve raised the issue with Cursor directly, and I will update with more info when I receive one.
Thank you for flagging!
Yuansi_Li
Feb 26, 2026 7:23 PM UTC
I’m having this exact issue too. It worked yesterday and didn’t today.
