Doug6
Jun 23, 2025 1:30 PM UTC
[Figma Buzz] - Zoom to 100% and Zoom to Fit
Hey team. I hope you are doing well.
I'm testing Figma Buzz and having a hard time to zoom to the real size (Zoom to 100%) similar we do on Figma Design. When I try to zoom it to 100% it works same as the Zoom to Fit.
Can you help me on that?
Doug Lazarini
Figma Desktop App version 125.4.9
Figma Buzz
Jun 25, 2025 2:00 AM UTC
Hi ​@Doug6
Thanks for bringing this to our attention. I'm checking with our internal team about the shortcut behavior and will update you once I have more information to share.
In the meantime, a potential solution would be to switch to Design mode and manually select "Zoom to 100%" from the menu instead of using the shortcut. Not the ideal solution, I know, but hopefully it helps until we can provide more clarity on whether this is expected behavior or not.
Thanks for your patience!
Toku
John_Goldsmith
Oct 14, 2025 3:03 PM UTC
Hi,
Is there any update on this for Figma Buzz?  My experience is that if you click Ctrl+0 a popup says “Zoom to 100%”, but given the custom size I’ve selected it looks to be about double the size that it should be.  This is on Windows with screen scaling of 100%.  Would be good to have some rulers so you could see what’s going on even if it only showed when an asset was visible.
Also it would be good if the zoom level could be left untouched when clicking between assets (using asset view tiles).  Currently it changes to fit every time.
Your design view zoom workaround works (thank you) but it’s not super convenient.
Thanks, John
John_Goldsmith
Oct 15, 2025 1:14 PM UTC
One update to this is that it seems to be dependent on the browser window size.  On a 4K screen with the window maximized both Ctrl+0 and selecting from the design zoom panel results in a zoom of 333%.  If you narrow the wide of the browser window down to a thirdish of the width then both actions performs as expected.
