brian.pr
Jan 29, 2025 3:42 PM UTC
Export Skipping Selected Artboards
When selecting multiple frames for export Figma will ignore some frames unless I go and manually export them individually. Is there something I am missing where when I group select 5+ frames and click export that I need to do to ensure everything is being exported at once, or is this a bug within Figma?
Gayani_S
Jan 30, 2025 2:02 PM UTC
Hey ​@brian.pr, thank you for reaching out!
One possible reason for this could be your export settings, can you check if "Ignore overlapping layers" is enabled?
This setting is turned on by default when exporting as a PNG, which means only selected layers are included while overlapping elements might be excluded. The way you select frames could impact what gets exported, depending on whether this setting is enabled or disabled.
You can find more details about this setting here: Export formats and settings. If you haven’t already, try disabling it and see if that resolves the issue.
If the problem persists, would you be able to share a screen recording of your export process? That might help pinpoint what’s going on. Let me know what you find, thank you!
