Fra123
Aug 18, 2025 9:23 AM UTC
Empty "filter" makes exported SVG nodes invisible
When exporting nodes with exportAsync({ format: 'SVG' }), the REST API sometimes generates <g filter="url(#id)"> references pointing to a <filter> element that has no primitives. According to the SVG spec, applying such a filter causes the group to render nothing.
This means that shapes with simple fills/strokes (e.g. Polygon, Line, Vector) can appear correctly in Figma, but the exported SVG appears empty in strict renderers.
Steps to reproduce:
  1. Create a polygon, vector or line.
  2. Add a drop shadow effect.
  3. Export via plugin using node.exportAsync({ format: 'SVG' }).
  4. Inspect the SVG: the node is wrapped in <g filter="url(#filter0)"> but <filter id="filter0"> has no child primitives.
  5. Open the SVG in browser → shape is invisible.
Expected result:
If an effect cannot be represented in SVG, the exporter should omit the filter attribute (or insert a trivial <feMerge><feMergeNode in="SourceGraphic"/></feMerge> so the geometry is preserved).
Actual result:
An empty <filter> is emitted, causing the element to disappear.
Impact:
  • Causes SVG exports from plugins to look blank in common viewers.
Request:
Please update the SVG exporter so that nodes with non-representable effects do not produce empty filter references, or at least provide an option in ExportSettingsSVG to suppress these empty filters.
