Alex Victoria
Jan 16, 2026 10:31 PM UTC
Design System Package Template Creation fails to remix into a new project based on the template
Hi I have published my design library to Figma Make’s private NPM repo as is described here https://developers.figma.com/docs/code/bring-your-design-system-package/.  I am able to create the project, install my library, and add all my guidelines files to the Draft and produce really cool stuff with my design system.  Editors on my team are able to click “Use in new file” and it works great for them as well.  However, once I publish a template for the whole org to use (that includes my installed library and guidelines (several files)), using the “Start from an example” chip creates a new Make project that is broken.  The guidelines are all gone and the package no longer installed, and it gives an error about missing Make files like follows:
❌ [vite] Internal Server Error Failed to resolve import "./styles/index.css" from "__figma__entrypoint__.ts". Does the file exist? at TransformPluginContext._formatLog (node_modules/.pnpm/vite@6.3.5_jiti@2.6.0_lightningcss@1.30.1/node_modules/vite/dist/node/chunks/dep-DBxKXgDP.js:42499:41) at TransformPluginContext.error (node_modules/.pnpm/vite@6.3.5_jiti@2.6.0_lightningcss@1.30.1/node_modules/vite/dist/node/chunks/dep-DBxKXgDP.js:42496:16) at normalizeUrl (node_modules/.pnpm/vite@6.3.5_jiti@2.6.0_lightningcss@1.30.1/node_modules/vite/dist/node/chunks/dep-DBxKXgDP.js:40475:23) at processTicksAndRejections (node:internal/process/task_queues:105:5) at node_modules/.pnpm/vite@6.3.5_jiti@2.6.0_lightningcss@1.30.1/node_modules/vite/dist/node/chunks/dep-DBxKXgDP.js:40594:37 at async Promise.all (index 1) at TransformPluginContext.transform (node_modules/.pnpm/vite@6.3.5_jiti@2.6.0_lightningcss@1.30.1/node_modules/vite/dist/node/chunks/dep-DBxKXgDP.js:40521:7) at EnvironmentPluginContainer.transform (node_modules/.pnpm/vite@6.3.5_jiti@2.6.0_lightningcss@1.30.1/node_modules/vite/dist/node/chunks/dep-DBxKXgDP.js:42294:18) at loadAndTransform (node_modules/.pnpm/vite@6.3.5_jiti@2.6.0_lightningcss@1.30.1/node_modules/vite/dist/node/chunks/dep-DBxKXgDP.js:35735:27) at viteTransformMiddleware (node_modules/.pnpm/vite@6.3.5_jiti@2.6.0_lightningcss@1.30.1/node_modules/vite/dist/node/chunks/dep-DBxKXgDP.js:37250:24)
Anyone running into this?
Cail_Borg2
Jan 19, 2026 6:51 AM UTC
Yes I am too. Specifically when I set up a Figma Make template, publish it to the org and try and use it afterwards. I can have the AI tool “fix” it - but it doesn’t carry over any of the styling of the original - which is kind of the point of creating templates in the first place.
Bri Camp
Jan 20, 2026 6:49 PM UTC
I’m having this exact issue as well! Figma Make template, published internally to the org, attempt to remix it, and run into the exact same error you mentioned. The files from the original template are not getting copied over.
I hope Figma can quickly fix this.
ksn
Jan 28, 2026 5:52 PM UTC
Hey all - I’m sorry it’s taken a while to get back to you. I had checked in with our engineering and technical quality team, and it sounds like this was a bug they recently caught wind of.
They believe this should now be fixed. Please try the following:
If you’re on the desktop app: please close and restart the app, then take a look at the file again to see if this is still occurring.
If you’re on the Figma website: refresh your tab and try again and see if the issue continues.
Let me know if this still occurs. Thank you for your patience!
