Design system library updates won't appear in other design file
  • May 6, 2025
  • 6 replies
  • 220 views
Berra
Even though I waited for a month to figma fix itselfs, it did not happen. So, I’m going to give it a try, since I’m getting increasingly fed up with this issue.
The situation:
  • I’m working on the component library for my organisation;
  • I publish the changes made;
  • I then go to the file in which the libary I just updated is used;
  • The is no notification of an update
  • When I check for updates in the assets panel there are updates listed;
  • I klick on “Update” and still nothing happens
So I am stuck with a library that refuses to update. It DOES however update when I close and reopen Figma. Any help here?
Jim_Knox
  • Active Member
  • May 6, 2025
Im having the same issue, its either incredibly slow and you don’t get an update, or the last update remains in the update window (even after updating), theres no feedback to tell me whats going on
  • Figmate
  • May 7, 2025
Hey ​@Berra and ​@Jim_Knox!
@Berra , I understand that the blue badge isn't showing up on the Libraries icon when there's an update, and even clicking "Update" in the "Manage library" modal does nothing. That sounds really strange.
I just tried it on my end, and it seems to be working fine for me. Thanks for letting us know that closing and reopening Figma works for you.
To help our team figure out what's going on, I'm creating a support request for you with the info you've already shared. Our support team will be in touch via email soon to help get this sorted. Keep an eye on your inbox for that new ticket notification.
While you're waiting for that email, could you gather the following info? It would be a huge help for the team:
  • Does this happen in the browser, the desktop app, or both?
  • The URL of your component library and the specific file where you're seeing this issue.
  • A quick video showing the problem.
Once you get the ticket confirmation email, please reply with this information.
And ​@Jim_Knox,  I understand that one of the library update issues you're experiencing is slow performance. Would you mind filling out this form? That would really help us move forward with the investigation. https://help.figma.com/hc/en-us/requests/new?ticket_form_id=29433525829271
Thanks so much to both of you for your help with this! We'll get this looked into.
Berra
  • May 7, 2025
Hello again ​@Junko3,
In our organisation, we use two different design files as library; Web design system file and App design system file. Web design system file works just fine. However, “App design system” file has the bug I described. I am waiting the your email! Thanks for the reply.
Captify
  • May 12, 2025
Hi,
I’m also having the same issue now, but even closing and reopening Figma doesn’t help, I’m completely unable to update my components.  Any fix for this yet?
Edit: randomly started working again!
Eric Quezado
  • July 21, 2025
I have exactly the same issue here at work. Initially I thought it could be because we are managing multiple libraries (foundation elements, app components, web components, etc).
However, at home, with my personal account, I just created a simple project with around 10 screens and 20 components in a library file. Same issue happening there. I basic developed the flow of closing publishing the library update, closing my target design file, and opening again, so I can see the updates badge.
Alex Barnes
  • November 19, 2025
I had this issue after publishing a new Design system library. It wasn’t showing up in the libraries added to this file. I solved it by manually searching for the file with the “Search all libraries” feature. It’s strange because you’d expect it to show up automatically.
