letspretend
May 28, 2025 1:39 PM UTC
Copy/Paste Properties not working
Currently Copy/Paste Properties doesn't seem to work at all. I have 2 simple rectangles with different fill colors and strokes. I copy one, then paste properties on the other. Nothing at all happens.
This is in the standalone app on Windows.
    Gayani_S
    Gayani_SSolution
    May 28, 2025 3:46 PM UTC
    Hey ​@letspretend, thanks for sharing a screen recording- really helpful! I reviewed it and it looks like the method you’re using is ‘Copy’, instead of Copy/Paste as > Copy properties, which might be why it’s not applying anything when you go to paste properties.
    I went ahead and tested both approaches on my end, you can see this in my screen recording. When using the regular ‘Copy’ option, I saw the same result as you, no properties were transferred. But when I used Copy/Paste as > Copy properties and then use Paste properties on the second shape, it works as expected.
    Could you try that method and see if it works for you as well? If it still doesn’t, let me know — I’m here to help troubleshoot further!
    Thank you,
    Gayani
    Gayani_S
    Gayani_SSolution
    Thank you,
    Gayani
    letspretend
    May 28, 2025 4:24 PM UTC
    Oh, I see now there is a separate “Copy Properties” function. I am almost certain this didn't used to exist, at least it doesn't in other tools that have something similar. You just “Copy” and then “Paste” has several options.
    Maybe I was just remembering it from other tools, where you just copy and then paste attributes. Dare I say makes more sense.
    I got a reply via Email, but it's not shown here for some reason!? So thanks for pointing it out Gayani_S
    Gayani_S
    May 29, 2025 9:03 AM UTC
    Hey ​@letspretend! You’re totally right, many tools handle this kind of functionality differently. Apologies I’ve just updated the sharing settings on the Loom video, so you should be able to view the screen recording now. Also here’s a direct link to our Help Center article if you want to more information on this: Copy and paste properties between layers.
    Charles_Walter
    Jun 10, 2025 4:56 PM UTC
    Hey ​@Gayani_S, I’m having a similar problem. I’m trying to copy interactions from one variable to another and it isn’t working. I’m on a mac and I’m using the “Copy Properties” selections. Unfortunately, neither opt+cmd+C nor the copy properties in the edit menu appear to work.
    Less than a week ago this was working fine, but since 6/7 or 6/8 I haven’t been able to perform this cut and paste function.
    EricaRW
    Sep 4, 2025 3:41 PM UTC
    The same! It doesn’t work! Please please fix ASAP, it’s a serious brake in work
    Gayani_S
    Sep 9, 2025 8:36 AM UTC
    Hey everyone, thanks for reaching out! Have you had a chance to look at the screen recording I shared in my earlier reply? In that example, I used Copy/Paste as > Copy properties and then Paste properties. If you could share a similar recording of the exact steps you’re taking, that would help me try to reproduce the issue on my end and pass the details along to the team.
    Thank you,
    Gayani
    Jake Schroeder
    Jan 14, 2026 5:38 PM UTC
    Evernote hijacked my opt+cmd+C shortcut at the global level. Had to disable in Evernote, works perfectly again.
