components overrides showing ‘component documentation’ instead of options
  • February 14, 2025
  • 20 views
LCruickshanks
I’m working from an Antd component library. Recently, the components stopped showing overrides. Instead, it shows ‘component documentation”.
I’ve tried clearing the cache and restarting. I’ve reverted the component library to 3 months ago (when the problem didn’t exist).
Not sure what else I can do.
  • Figmate
  • February 18, 2025
Hi ​@LCruickshanks, Thanks for reaching out about this.
I understand you're having difficulty viewing specific overridden properties. Could you please try the following steps?
  1. Select a layer in the instance that already have overrides applied.
  2. Click the “More actions” [•••].
  3. Hover over the “Reset” menu.
I tested on my end, and when I select an overridden layer within an instance, a menu appears that lets me reset that specific property.
I hope this helps clarify things. Thanks again for getting in touch!
