Component instances not updating when master is updated
  • September 23, 2025
  • 34 views
Angela Liu
I created this error message field, realized later there was a better way to set it up so changed the layout to this:
I have some modals with form fields in them. There was a button to update the form fields within the modal, so I clicked it. However, the modals are still showing the old layout:
I don’t want to go through and manually update every single form field. How can I get all of them updated at once?
  • 5228 replies
  • October 1, 2025
Hi ​@Angela Liu, thanks for reaching out and apologies for the delayed reply!
Is your main component in the same file as all of your instances?
While you can choose to push any instance changes back to the main component, which in turn, will update any other instances of that component, please note that you can only push changes if the main component is in the same file as the instance. It’s not currently possible to push changes to components in another file, including published libraries.
More information here: https://help.figma.com/hc/en-us/articles/360039150733-Apply-changes-to-instances#%E2%80%9Ch_01HXD7C9W87GVVS615YC813WK1
