David Isayan
Dec 31, 2025 8:13 AM UTC
Code Connect: getProps() returns undefined for linked library component instances
I'm using Code Connect to connect our design system components. I have a Button component that contains an Icon instance swap property. The Icon components are defined in a separate library file and each has its own Code Connect.
  Setup:
  - Main file: Contains Button component with an "Icon" instance swap property
  - Library file: Contains 2000+ Icon components, each with Code Connect published
  Icon Code Connect (published to library file):
  figma.connect(Icon, "https://figma.com/.../IconLibrary?node-id=11-15001", {
    imports: ["import IconAdd from 'my-icons/add.svg'"],
    props: {
      svg: IconAdd,
    example: () => <Icon svg={IconAdd} />,
Button Code Connect (published to main file):
  figma.connect(Button, "https://figma.com/.../MainFile?node-id=295-102", {
    variant: { Icon: "Left" },
    props: {
      iconProps: figma.instance("Icon").getProps<{ svg: React.FC }>(),
    example: (props) => (
      <Button icon={{ before: props.iconProps.svg }}>Button</Button>
  Expected behavior:
  When selecting a Button with Icon=Left in Dev Mode, I expect:
  <Button icon={{ before: IconAdd }}>Button</Button>
  Actual behavior:
  props.iconProps is undefined, so the output fails or shows:
  <Button icon={{ before: undefined }}>Button</Button>
  Workaround attempted:
  Using figma.instance("Icon") directly (without getProps()):
  props: {
    icon: figma.instance("Icon"),
    <Button icon={{ before: props.icon }}>Button</Button>
  Workaround output:
  <Button icon={{ before: <Icon svg={IconAdd} /> }}>Button</Button>
  This shows the nested Icon's Code Connect snippet is working, but I need just IconAdd, not the full <Icon svg={IconAdd} /> wrapper.
  Investigation:
  Using Figma MCP's get_code_connect_map, I see:
  - Icon instance inside Button: version: "component_browser", snippet: null
  - Standalone Icon in library: version: "figmadoc", snippet: "<Icon svg={IconAdd} />"
  The linked library instance appears to use component_browser instead of my published figmadoc Code Connect, which may explain why getProps() can't find the props.
  Question:
  1. Does getProps() work with linked library component instances?
  2. If yes, what configuration am I missing?
  3. If no, is there an alternative approach to extract specific props (not the full snippet) from nested library components?
