Can't adjust letter spacing between 2 lowercase f
  • April 15, 2025
  • 121 views
Krystal Weng
I tried to set the letter spacing to be 20% on using the font Proxima Nova, but when I type the word “Office”, the letter spacing is not showing the way I set after each lowercase “f”. No matter how I change the letter spacing, the letter after the lower case “f” always stick with the “f”. This situation only happens with the lowercase “f”, I’ve tried other letters the letter spacing works fine. Does anybody know how to resolve this problem? I have attached an image to better interpret the problem.
Best answer by Raphael_M
or you can turn the ligatures off in the typography properties
sorry, this is my first time looking at this properties.
Raphael_M
  • April 15, 2025
https://www.marksimonson.com/notebook/view/proxima-nova-2.008/
I think that’s intended as part of the fonts ligatures. (f, i, l, j) based on what I saw on its ligatures.
You can’t legally modify it even if you buy the font. So, I suggest to just manually space them.
Raphael_M
  • April 15, 2025
Krystal Weng
  • April 15, 2025
Thank you! Turning the ligatures off fixed the problem! It’s my first time noticing this feature too!
