Andy Tuohy
Nov 4, 2025 11:22 AM UTC
🐞 Bug report: Buttons flash when clicking anywhere on a frame (even outside the button)
I’ve discovered a reproducible prototype bug where any layer with an β€œOn tap” interaction briefly flashes or shows its pressed state even when clicking anywhere else on the same frame.
How to reproduce:
  1. Create a new file with two simple frames (e.g. Home + Next).
  2. Add a rectangle on the Home frame and give it an interaction: On tap β†’ Navigate to Next.
  3. Run the prototype.
  4. Tap anywhere except the button β€” the button still flashes as if pressed.
Expected: Button should only show its pressed/active state when tapped directly.
Actual: The button reacts visually on any click within the frame, even on empty space.
Tested in both browser and desktop apps (latest versions, Nov 2025) β€” same behaviour, so this appears to be a global bug rather than a file-specific issue.
