BUG: Issues with final column in Variable editor
  • November 14, 2024
  • 27 views
Johnson_Ryan
I’m loving that I can now resize columns in the variable editor. However, there are some issues with this feature, specifically with the final column.
Problem #1: Cannot resize last column
  • Open a variable collection with numerous modes (enough that will require scrolling to the final mode column).
  • Try and resize the last column
Problem #2: Final column fills available space
  • I have to resize the Variable editor dialog to best view variable definitions for a specific collection (making it wider).
  • Switching to a variable collection that has only one mode column forces trailing elements in the final column to be aligned to the right edge of the dialog (nowhere near the column value).
  • November 15, 2024
Hi there,
Thanks for flagging this! We’re aware of this issue internally, but we don’t have an ETA at the moment. We’ll let you know as soon as there are any update
Thanks for your patience!
Toku
